ABS, Traction, Low PSI Lights Simultaneously Coming On/Going Off
Guys...
Okay so a while back this happened and went away after a few minutes, but now its on more often than not, and will disappear. They all come/go in unison. Scan Gauge revealed nothing and I really don't notice a difference in braking/driveability. The tires are good and properly inflated. I'm assuming its either some loose, shared connection between the systems or a bad sensor as its not a permanent condition. I was planning to drive from St. Louis to Lake Geneva Area in WI this weekend for 2 concerts. Anyone have any idea what this could be, where I should start to investigate under the bonnet, or if I should take my GF's car instead? Please let me know your thoughts.
Definately a Wheel speed sensor. It could be any of the 4 wheels. Your two choices to track it down are finding a mechanic with a code reader that can read MINI ABS system codes, or getting under the car and finding the problem yourself. Before you actually replace any sensors, try and clean the plugs/wires as general dirty and gunk buildup can cause them to lose signal.
Also, Search for "Trifecta" and you should get a return on more of these threads.
Thanks a ton for the prompt, post-midnight responses. Time is running short on this. Searching "TRIFECTA" was a huge help, so thanks a lot for that suggestion (my search yielded results all over the map). That all said, there are still a couple inquiries... I think I know what I'm looking for now, but I'm yet to find any connection point and plug to examine. If anyone can better explain what it looks like and/or where it is, you may have my first born. More importantly, I understand - having read some posts the search turned up - that the affected wheel will not have ABS active on it as a result of the error code/issue/what have you. Aside from that detail, does anyone see any danger to car and/or driver in logging between 1000 and 1200 miles on it this weekend?
Finally, Agarwaen, you referred to error codes. I have a scan gauge that has revealed nothing on this matter. I guess I figured the thing only ran engine-related codes. Does anyone know if that's correct? I assume I need a different tool, or is it a BMW-Specific diagnostic tool?
When I was having wheel speed sensor issues last winter, my mechanic was able to read the codes using a Solus Pro scanner -- a nice professional-grade piece of kit -- but I'm sure anything comparable would work.
When I looked at mine a few days ago, I didn't see any damage to the wire. I did have a lot of trouble getting out the bolt that holds the sensor in (on both sides of the car.) I thought they were going to break off!
Now that the weather has been dry, my lights are off. That and how much rust was on those bolts, I am guess when I get the sensor out (it is stuck) I will probably find a lot of corrosion.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
08-12-2015 01:24 PM
