Ejected Plug
on
Ejected Plug
Alright, well as many of you know, earlier MINI's are notorious for "ejecting" sometimes stock and most of the time aftermarket spark plugs. Yesterday I was the struck down by this curse of having an aluminum head and aftermarket plugs. I have been driving on my brisk plugs for a little over 10k. They were torqued correctly and my car only has 55k on the clock. But, this is where is is a little different... See my plug didn't shoot out of the cylinder head, it stayed some what threaded and I believed it was only loose until i tried to torque it back down it spun like Alice falling down a tree trunk in Wonderland... It was bouncing around in the tube and it was a b**** to get out. Today, I went to mess with it and tried to replace the spark plug with a different one. Surprisingly, this spark plug threaded and torqued and I proceeded to drive the MINI home from work...
Now, I believe the threads are weak in the head and I have a very strong feeling the plug will get ejected once more and make a very large mess. On the other hand however, is there a possibility that my previous spark plug was just jacked and didn't want to stay in my motor... Also, the end of the threads on the spark plug were rounded (not tapered) if that helps. I understand the expansion and contraction in that area of the engine hence why I am asking if it will happen again....
Sounds like that particular plug was cross-threaded. At a minimum, you may need to retap the plug threads in the head. I read in a past thread that you can stick panty hose into the cylinder to help catch all the metal shavings. Read more here: https://www.northamericanmotoring.com/forums/stock-problems-issues/184691-pulled-plug-2-soaked-in-oil-and-metal-bits.html
on
I am firmly in the 'if it ain't broke don't fix it' camp.
If you are planning a head swap anyway get that reserve head cleaned up and ported and make the switch. (don't forget the upgraded cam)
on
Not on topic but kind-of, make sure you stay in school and eventually you get the point after graduation when funding gets much easier.
on
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
