New o2 sensors and still throwing a code.
I have an 03 MCS. 60,000 miles. SES light came on my neghibor w/ a computer plugged it up and said o2 sensors were bad. I replaced pre and post 02 sensors. Reset the computer and about 60 miles later I got the SES again stating it was the pre o2. I am going to try to switch the pre and post to see if I got a bad part. My question is, What are the chances its the wiring harness? (It seems to be in good shape). Also if I reset the computer from the gauge cluster will that clear my SES codes or do I have to plug it in to a computer?
Thanks,
Brennan
Thanks,
Brennan
If the PRE cat O2 is throwing a code...check to see what the code is....it is often due to running lean due to un- metered air...a leak.....find it, and the code will go away!!
The post O2 is usually due to a failing cat..
Were they OEM O2 sensors? A few techs swear that the aftermarket ones (universal) throw codes...and a few of the better techs here have said similar things....
And you must have an OBD-II scanner to read/re-set the codes.....and many basic ones cannot re-set/clear some codes!!
sempaipaul
09-18-2015 03:05 PM
