Armrest - anyone removed it?
I hate the armrest. When its down I can't shift comfortably, and when its up its not really out of the way. There is this barrier between me and my passengers since it doesn't fold up flush with the seat back.
This is the "new" armrest I am told - the top doesn't slide. It appears to be attached to a big industrial looking metal bracket that goes and hides by each seat. Is it easy to remove/unscrew? The dealer said you have to remove the seats to do it! They've gotta be pulling my leg, right?
Gabe of MotoringFile removed the armrest on his R56, and he said it was not an easy job to make it clean like from the factory without an armrest. You would have to completely take apart the center console and replace several parts with non-armrest versions. Look at this page: http://www.realoem.com/bmw/showparts..._6288&hg=51&fg. The cupholder is different (items 14, 15) but the main difficulty is changing the handbrake bracket (item #2).
Without doing the complete job, if you don't mind it looking a bit funky, you can just unbolt and remove the armrest itself by removing the cupholder to access the screws.
the top dows not slide back it sounds as if it is the Euro Style and those are much easiery to remove.
If the brackets holding in place look like these then it is much easier to remove.
http://www.outmotoring.com/mini-coop...h_storage.html
1. remove torx bolt from the rear of the seat base track nearest the arm rest bracket
2. slide the brackets out from under the sseat base track.
Everyone has their own opinion, but glad to hear you are now happy.
I have the dealer installed one (like the one linked above) that I paid $400 for including install. Good thing I love it or I would feel like it was wasted money. Though I could have saved by installing myself if I had known how easy it was.
Looks like it will be an easy removal though if I ever decide to. Thanks for the pdf link.
on
I added the factory armrest to my car.
To convert your car it is fairly easy, the hardest part is lifting the console, but it is not too difficult to lift the console up, you just have to be gentle and patient. Careful of the wires beneath and the clips.
You will need to re-use your fasteners.
on
Yes they are!
Here are parts you would have to order (MSRP price):
51162756167 $12.82 cupholder
51162756171 $11.03 trim ring silver
51162752947 $11.40 bracket
FYI, no affilation just a happy customer, parts.com seems to have the cheapest prices MINI/BMW on OEM parts online.
on
And for those lifting their console to change the bracket (to add or delete the armrest), here are good instructions for doing so.
http://www.robincasady.com/ShiftKnob...otInstall.html
And I have to say be very careful with the ebrake button cover, I broke one of the tabs off.
07-16-2020 12:54 PM
F55/F56 Latest Mini Connected App . . .
Crimguy
09-10-2015 01:07 PM
