Power window parts?
Power window parts?
I have an 03 S and am having some problems with my passenger side window. I pulled the door panel off and noticed that the white clips that hold the cable are broken. I can get the motor to work but within a couple of days is stops. The broken clip has also torn the tint on the window. Does anyone know if someone sells those clips or am I stuck buying a new regulator? Thanks in advance.
Im not exactly sure which clips you are talking about but regulators are not repairable in the field. No dealer parts available. If the motor works and then stops but comes back to life there is either an internal motor problem or an electrical problem unless there is something else with this broken clip
07-16-2020 12:54 PM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
12-23-2015 10:36 AM
