Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
im losing my mind, on the rear brake i cant get the piston back far enough to put the shoes on, im only doin the rear
AND YES I HAVE THE RIGHT PARTS i have the drivers side done already
the passenger side is givin me all three shades of hell
MY QUESTION
is there some magical way to move the piston back further? i have it in a vice and I tried bleeding it already
im a pretty big guy so i mean its on there i just cant get it to move...at all
i use needle nose pliers.. push and twist.. eventually the thread will catch and the piston will move in.. takes some force, is a pain until it moves and then you will know the trick! I sometimes hold the caliper against the pad carrier to get some good leverage.
I wouldnt use a c-clamp or anything that doesnt push or rotate at the same time..
I think what Some Guy was saying was that the C-clamp rotated with the piston, so that the piston rotated when you tightened the C-clamp. At least that's what happend when I used a C-clamp, before I got the HarborFrieght tool (which I much prefer to the C-clamp).
The C Clamp can work but sometimes when the calipers are older and the E brake cables can be sticky it tough to get enough twisting force from the C Clamp. That rear piston tool makes everything so easy and fast
This. Sorry if I was unclear, the piston did rotate on the way back in.
