flat tire light
flat tire light
hey guys
i am new to mini's, i get made fun of a lot because i traded my harley davidson in on one. i have a 06 and last night it just would not start so today i put a new battery in and started right up the only thing now is the low tire presure light wont go off. i tryed reseting it like the book said but it just wont go out. i did the turn the key too 2nd position and hold the button down for 30 seconds and then start the car and it did nothing. is this something that maybe i need to unhook the battery again and it will reset? any help would be great i also checked the presure and all is good.
sean in v.a.
sean in v.a.
A solid tire light usually means something could be wrong with the wheel speed sensors, flashing is when tire pressure is off. Those are used to help run the anti-lock brakes, dynamic/automatic stability control, electronic brakeforce distribution, and corner brake control systems. It could be a mild safety hazard. See if you can get the OBD II codes read at an Autozone.
07-16-2020 12:54 PM
ltjpunk7
09-06-2015 07:32 AM
Powershift
08-16-2015 05:14 PM
sabjcw
08-14-2015 07:40 AM
