a/c compressor clutch
I looked at it and it is not spinning. I checked the fuses and they look good. Not sure how to test the relay so i pulled it and reseated it. freon was 130psi on the low pressure port. added freon to see if that would help. nothing. Anything else I should check? Or is it time for a new compressor?
Vendor
Sounds like you may have a bad compressor. New ones aren't cheap. Tomorrow we are test fitting a more affordable aftermarket one. If it works it will save customers a couple hundred dollars. Other aftermarket ones we've tried in the past didn't fit or failed quickly.
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
Are you sure the compressor is bad. Just because it isn't turning doesn't necessarily mean it's the compressor. The clutch has shims to adjust the space between the clutch and the compressor plate. When the clutch wears normally, you have to reduce the spacing to ensure engagement. Once too much distance, the magnetic pull won't allow for the compressor to engage properly.
A much cheaper fix.
A much cheaper fix.
Khai
02-10-2016 07:43 PM
FatherG
09-20-2015 08:26 PM
