Oil on spark plug
on
Oil on spark plug
So I went to go to work today and as I started my car I noticed it just wasn't running right. So I just took it around the block....had no power at all, and a CEL came on. I read the codes as P0300 and P0304. Well reset the codes, and started the car, same results. Then decided to take the plugs out and check them. They are fouled, which after 40,000 it's time to change them anyways. However....on the #1 plug it was soaked in oil. I'm kind of nervous and freaking out a bit as to what would have caused this problem!
I have lots of aftermarket work done on my car....only internal change is a Crower Cam Shaft. Was no problems at all recently.....changed oil two weekends ago, and all was well!
Help!!!!
Help!!!!
on
on
Well did compression test and everything was good....all 4 cylinders were spot on....nothing off there.
I also tightened down and retorqued down the valve train, cleared all the CEL cods, changed the plugs, ran seafoam through engine, put everything back together and it runs well now. Guess we'll see if things stay running well.
Seems odd to me that out of no place it started giving big problems though....there were no signs at all, then boom! Oh well.....thanks for your help everybody.
But still wondering if theres a way to check the valve guides and make sure that they are in good shape. Is it better, cheaper to upgrade the whole cylinder head to an aftermarket or just upgrade the valve bodies and valves in the stock "S" head? Thanks!
silence2-38554
98
09-21-2016 02:52 PM
