Fuel issues
Fuel issues
Very odd...nothings changed mod wise in roughly 1200mi but recently my mileage has dropped dramatically.
I went from a 23mpg avg/tank to 19 (real calculations not scan gauge stuff...23mpg avg based on 8tanks of gas). Scangauge shows a drop from 54 to 29 (50mph 6th gear cruise control same road) real time mpg and from 32 to 21 avg (same route same habits all that jazz). It's my to and from work routine so Its pretty consistent in route, speeds, habits ect
Today it got worse. I'm at a 1/2 tank and the only thing that's changed is the weather (10deg). Scangauge reports 14mpg avg over my route and my 50/6/cc test was 16![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
I've checked tire pressures all that jazz. It really confuses me because performance hasn't been effected. It starts right up and runs strong. I have noticed on occasion it idles rough but nothing consistent.
Thoughts comments ect? It's semi-heavily mod'd so I don't expect aceptional mpg but seeing it drop like this concerns me. I'm leaning tword fuel filter possibly pump (102k) but I'd think it'd fall on it's face up top. When Jan tuned it over 1200mi ago it ran lean on the dyno and he mentioned pump/filter.
I saw one of gray-raven's posts talkin bout winter gas and I was like WTF is that ![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
Our winter generally consists of 3 days of sub 50* weather and about 3mo of people walkin around in parkas when is 75 out
I had a friend scan it (BMW tool not scangauge to avoid confusion) and among some unrelated airbag garbage there was a CAN bus error at 66k. I didn't own it till 96k and I have no idea what that means but he mentioned that it couldn't clear itself. He also said something about my rear o2 sensor needing to be turned off because I'm catless. Being from the land of k-jet and 80s gray market cars I have no idea WTF that means either
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
Well I've got the fuel filter already so it's going in...just a matter of "was that the problem or am I just ****" ![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
Are there crossover parts? Can I pull injectors and an o2 sensor from a ford for example? I know on my old e30 I stole my buddies lighting **** to test and everything worked fine. Is there a wideband I can throw in there?
I'll search for PNs shortly but I think o2 makes sense so I'll probably pick a couple up and do em
I'm trying to get all the little **** on the mini fixed/replaced/worked out whatever so it can be a bullet-proof "DD" for a few months while I work on my merc. I'm replacing the motor and painting the engine bay/replacing a bunch of little **** I can only do with the motor out so I can't afford to have the mini break while my 2nd car is down
Thanks for the question though....come again!
I changed my fuel filter out myself. I used this link as a reference:
https://www.northamericanmotoring.co...hange-mcs.html
09R56
11-16-2022 10:49 AM
alex87f
03-25-2017 03:46 PM
silence2-38554
98
09-21-2016 02:52 PM
bc219
08-10-2015 11:22 AM
