Where Is The Coolant Going
Old 11-21-2010, 07:17 PM
pyrows666's Avatar
pyrows666
pyrows666 is offline
1) So incase it is a head gasket... what should i do while the head is off? ARP studs?? Is there a better Gasket (metal gasket?) should i port the head? oooooo
2) Could it be anythink else besides the head Gasket? is there an oil cooler?
  #27
Old 11-22-2010, 01:40 AM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
Head/headgasket is the most likely failure....
Could be an oil cooler (unlikely to fail, but possible) or even a crack in the block or head....
What you spend $$ is up to you...depends on what you need to do and the $$$$ you have to spend!!
  #28
Old 11-22-2010, 07:33 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Originally Posted by pyrows666
OMG OMG OMG the oil changed in to MilkShake.... No leaking nothing leaking... still takes 3 days for the resivour to empty..... Head gasket i assume... unless there is a oil cooler leaking some how in the coolant....
Sorry to hear that. That needs to be sorted out right away.
I'm hoping that doesn't happen on mine before I get around to fixing it,
since I depend on mine as my daily driver.
  #29
Old 11-23-2010, 05:21 AM
pyrows666's Avatar
pyrows666
im trying to think about what i can do performance wise.... this would be great opertunity for like... CAM... Porting..... hmmmmm anyone have any ideas?
  #30
Old 11-23-2010, 07:55 AM
steve20607's Avatar
steve20607
steve20607 is offline
That's what I'd do.....make a spread sheet of the cost of the OEM parts versus the performance items and find someone who can rebuild it for you if you're not mechanically inclined.
  #31
Old 11-23-2010, 03:37 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
Big hp is in a head and cam...but $$$.
Since the head must at the very least come off, you will save the cost of a headgasket, labour, and maybe the studs...so not a huge savings...but if you were going to do it someday, might make sense.
But as we speak, the motor needs to be opened up to determine the failure, and the corrosive antifreeze removed from the motor...ASAP. What you find will help you decide what to do...
  #32
Old 11-23-2010, 03:39 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
And with 140,000 miles, a compression check might be a good idea..hard to do now...investing $$ in a weak motor with bad rings when a rebuild is needed is not smart...make sure you have a good foundation to build on....
  #33
Old 11-25-2010, 06:00 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
My leak has slowed a little. Still there on short trips, but now usually seals up after 5-10 miles of driving.
The MINI is going in to my local MINI-friendly place in a week and a half, and if they confirm my diagnosis,
then I think I'll order a ported and polished head with an NS1 cam and have it installed a few weeks later.
BTW, only 55K on mine after almost 8 years.
  #34
Old 12-06-2010, 05:57 PM
snowmanmini's Avatar
snowmanmini
snowmanmini is offline
need an opinion...replace the housing, t-stat and gasket - or just t-stat and gasket? If I had the luxury of time I could open it up, inspect and then order the parts. Just wondering if others have found the housing to be part of the problem. Thanks!
  #35
Old 12-06-2010, 06:06 PM
ericfreeman's Avatar
ericfreeman
ericfreeman is offline
I'm a bit like you, don't have the time/space to pull something apart only to find I need another piece. T-stat housing is around $35 or so which puts it in the category of 'why not?' have it on hand in case you need it. I'd hate to have to do the job twice just for the sake of a $35 part. I can always earn another few $ but can never get the time back.
Eric
  #36
Old 12-06-2010, 08:03 PM
GreenR53's Avatar
GreenR53
GreenR53 is offline
I appear to have missing coolant as well... Noticed the fans on after a little romp the other day. Just checked after reading this looks like Ill be headed to get some BMW coolant tomorrow.
  #37
Old 12-07-2010, 05:49 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Went to the shop, it was a thermostat housing/gasket leak after all. Gee, the one I had replaced in 2/2009 didn't last very long, did it?
Maybe it got done in when the low speed resistor went out on my radiator fan. Wasn't visible to me at the housing itself, but it
apparently was coming out the bottom and running around a lip on the top of the block to the back of the engine, and that made it
look like it was coming from the head gasket to me. So it's not a cylinder head gasket leak after all.
Good news - much cheaper repair. Bad news - I don't have an excuse to replace the head "while it's off anyway" with a better one.
Good news - that would have been even more expensive anyway.
Pyrows666, how's your's going?
Steffen.Johnson
42
01-25-2023 02:47 PM
vulkandino
10-31-2015 08:29 PM
navybsn
10-04-2015 03:27 PM
point665
09-29-2015 12:41 PM
silence2-38554
09-28-2015 12:19 PM
Quick Reply: Where Is The Coolant Going
