Hood scoop warped form heat
Yes. As common as it gets.
Here's just one thread of many you'll find if you take the time to do a search in the 2nd Gen Stock Problems Forum:
https://www.northamericanmotoring.co...s-melting.html
Well that's interesting. When did MINI come out with this? This should be included with replaced hoods scoops under warranty. Hmmmm.
on
Went to my dealer today with warped hood scoop. It was covered under warranty...and I was able to upgrade to a carbon fiber scoop for $110. Having to sell parts from my 2003 MINI to pay for it...but worth the upgrade.
I also think the carbon fiber scoop is worth at least 1 to 2 more HP....anyone agree???
I am in the discovery phase of purchasing a 2011 Mini. One of the many things I have gleaned from the forum is the heat tranferred to the hood and scoop. I test drove a MCCSa and placed my hand on the hood after the drive. The intake scoop was very warm and the metal just behind it was HOT...to the point of not being able to leave my hand on it. I then drove a JCW MCC with quite different results. The scoop was near ambient and the metal behind it was barely warm. Both were checked within a minute of shutting down the engine. The only difference was the cooling fans were running on the JCW (engine was off). Had they recently run on the MCCS, I don't know. What would be the reason for this huge difference? If it is the fact that the fans were running it seems as this issue would be a fairly easy fix.
gary
gary
on
... I test drove a MCCSa and placed my hand on the hood after the drive. The intake scoop was very warm and the metal just behind it was HOT...to the point of not being able to leave my hand on it. I then drove a JCW MCC with quite different results. The scoop was near ambient and the metal behind it was barely warm. Both were checked within a minute of shutting down the engine...
... The only difference was the cooling fans were running on the JCW (engine was off). Had they recently run on the MCCS, I don't know. What would be the reason for this huge difference? If it is the fact that the fans were running it seems as this issue would be a fairly easy fix.
Can't believe BMW still hasn't corrected the real source of the scoop droop problem! Dealer replaced mine twice on my '08 MCS before I decided to correct the heat demon myself. The heat damage occurs not while driving, but when you stop and park. The scoop is non-functional and when stopped there's no way for engine bay heat to escape. I was seeing scoop temps of +250deg! The scoop sits just a few inches above that 1200deg turbo and the factory heat shield is just to keep idiots from reaching in there and touching it. I put on a m7 heat shield and JCW CF scoop with no grill and problem solved with no issues after 35K. It's still unnerving to see the heat waves pouring out of the scoop when you park.
I removed the plastic shroud from my scoop so that it can be semi-functional, and it has worked flawlessly. No purchase necessary. It actually allows air to be aimed at the block itself helping to eliminate excess heat that just idles under the bonnet. It won't help performance, but now my scoop won't melt even under the hottest conditions (well, maybe if it breaks 100 degrees).
The only warning I'll give you is that you should MAKE SURE YOU PLUG THE SCOOP WHEN YOU WASH THE CAR OR DRIVE IN THE RAIN! The wires on your engine are covered, but that's only to protect it against a bit of water. If it's raining, you'll the the block soaked and may cause something to short out. This is also true for when you wash your car.
I have a bit of warping in the middle-top portion of my scoop, but it's hardly noticeable to the naked eye (unless someone owns a Mini or something). It hasn't progressed any further since.
Hi, Im getting mine looked at next week for the dreaded melting issue as well but I got a lot of push-back on the phone from the guy over a carbon replacement. Does anyone who did a carbon inlet under warranty have any details? I would love to not have mine melt again in 9 months after I'm out of warranty, just because these things are junk and they wont address it properly. I love the car but its disheartening and sad to see a high end Deutsche manufacturer treat their customers like GM in the 1980s.
Harley, ^
Both of my scoops started with the chrome finish peeling/cracking but soon after, the scoop appeared "lifted" from the hood of the car. In other words, a little space developed where the scoop used to lie flush on the hood. Just a tip in case you want to keep an eye on it. Its appearance might change and evolve as the shield is exposed to more heat.
