Resonator/cat rattling?
on
So since I purchased my r53 one month ago I noticed a little rattling at around 2.5k rpm in first and second gear. I am quite sure its the resonator or a cat? I can't target it exactly. Anyone have the same problem? Could it be the cat? It really makes me sound like a beat up rice box when it rattles. Any input would be greatly appreciated! I am running the OEM r53 exhaust.
Thanks all!
Thanks all!
With the run running, and someone working the accel pedal for you, listen for the rattle. Since you have the stock exhaust (assuming not a JCW car), your cat is in the front near the engine while the resonator is in the rear (looks like a muffler). You might even be able to tap on the resonator to get it to rattle. If you have a JCW exhaust the resonator is in the middle of the exhaust with two small mufflers in the rear.
Thanks all!
Thanks all!
on
I have 66k on the car as it sits the exhaust is completely stock and its just an s non-jcw. It seems to be coming from the rear which is why I am assuming its the resonator. By the way is this something I can fix by cutting out the resonator and knocking the baffle out? Would this be too much work?
Thanks for the useful replies everyone!
torpeau
10-08-2015 11:10 AM
Jim Ferrell
10-06-2015 08:09 AM
eliseo1981
09-30-2015 07:57 PM
Nicefeet
09-24-2015 06:53 PM
