Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
I noticed while turning into my driveway to the right I hear a shooshing sound from my front left tire, I also noticed that if I'm taking off from a stop sign and go either right or left I feel a intermittent wheel hop 2-3 times and everything is fine.
I'm thinking it may be my wheel bearings or perhaps a bad control arm? Any help would be great.
You think a CV Boot would be causing these issues? I'll take a peek under the car and see.
Sort of.... the boot causes the CV joint to go bad which causes noises during turns often (like a grinding)
This may not be the issue, but worth a check..
Originally Posted by rickyr53
My CV Boot has been ripped for a couple weeks.....i should fix it soon. Mine hasnt been making any noise at all.
It won't until all the grease is tossed or washed out and the thing tears itself apart. Checking the boot is a quick way to narrow it down, though it isn't impossible the thing is a bad without the boot torn, as far as I know, a torn boot always ends badly.
My front left CV boot seems fine, doesn't look damaged or torn at all. So I doubt this may be my problem. Anybody else have a hunch concerning this issue?
It's the shock tower combined with what might be the axel. I had the same issue. If you don't get it fixed the shock will be soon to go. I waited and had a $2,300 dollar job done by mini. Ouch.
