Shutting off the TPMS ,for winter ( how )
I just removed my alloys for the winter ,I installed a set of steelies with snow tires. The Steelies don't have sensors so the indicator on the dash is showing low Tire pressure . Is there a way to disable this function so that when I have my snows on I don't have to look at the warning light . Any help appreciated, 2007 Mini Cooper S..,6 Speed
There is already a thread on this in the Modifications>Electrical Section.
https://www.northamericanmotoring.co...able-tpms.html
It will give you all the info you need to know.
But the easy answer is it is not a normal user adjustable setting.
Yea you have to take them out... The problem is multiple sets of wheels. It either buy another set of sensors, or live with the light... I just was going to remove them from my other wheels when I ditch them come spring (hopefully). Now I am currently running my winter setup. It would be a PITA to put those sensors in the winters, then again in whatever new ones I get, unless I never plan on running anything else after that, which is possible.
freeman727
12-10-2017 04:00 AM
