Fault code P1128
Fault code P1128
Hey everybody, does somebody know what the fault code P1128 is? Per Autozone they used the Volkswagen codes and it says:
Definition
Long term fuel trim B1 system too lean
Explanation
Failed MAF
Probable Cause
1. Low fuel pressure
2. Vacuum leak on engine
3. Failed H02S (Heated oxygen sensor) Bank 1
Is this the same for the MINI? If not, what could this be? Anybody ever run into this code and how did you fix it?
Thanks!
Ed
Definition
Explanation
Failed MAF
Probable Cause
Thanks!
Ed
Yeah, it threw a CEL last night. I checked the oil and I was about a quart low and filled it up. (Long story short, last time I had the symptoms of the timing chain rattle AGAIN, they said I was low on oil.) So I drove off and it was still on and still felt a little sluggish and was acting a bit wierd. Drove around today and it's been fine. I wonder if the MAF is dirty or I need a new O2 censor? I was kinda hoping it was the HPFP so I can finally have that replaced. I really don't want to go to the dealership.
Steffen.Johnson
71
01-26-2021 09:11 AM
ShadyCoop
09-20-2015 08:57 AM
sirfrank
09-11-2015 01:36 PM
