Removing the interior A Pillar trim
I am going off of memory here so I may not be 100% accurate. I believe I began by pulling the plastic trim away from the pillar near the top of the trim. Then you have to release 3 metal clips/latches from the trim piece with some pliers (not an easy task because of space). The metal clips have tethers on them that mount to the body of the car so when the airbag deploys the plastic trim can move away yet not fly into the driver/passenger. If you have trouble releasing the clips you can try removing the screws that mount the tethers to the body (also not an easy task due to space).
I had the same issue about a year or so ago and it was a seal under the hood. I cannot remember all the details and I am not where I can even look at my car right now. However, look under the hood, right in front of the passanger area. If I remember correctly there is a "well" area where the blower motor and stuff is and there is a seal that sits above that area that went bad and I had to replace it. It seems to me that the seal only diverts the water, but when it is bad it lets the water just run right in. I actually think I discovered it by accident. If I get a chance to look at my car later I can try to be more discriptive and maybe even snap a pic.
PelicanParts.com (09-19-2017)
Kimolaoha
07-05-2023 02:04 PM
07-16-2020 01:54 PM
quality_sound
08-07-2015 10:36 AM
