Purchasing thermostat gasket only?
if that's the case (and it is hard to believe cuz when I needed just the o-ring for the oil filter it was available se'ly fm the dealer) just save the old one as best you can, go to the autopart store and buy a sheet of gasket material for a couple of dollars, trace it out and cut your own. I've made several different Mini gaskets this way when they were available but at a crazy price.
It is not a flat gasket
It is a formed gasket made out of a silicone type material. Mini did change the material, so hopefully it will last longer now
I even went to the Chrysler dealer, as the thermostat is a Chrysler part, and the Neon gasket is close.....but not close enough
![No](https://www.northamericanmotoring.com/forums/images/smilies/no.gif)
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
![Frown](https://www.northamericanmotoring.com/forums/images/smilies/frown.gif)
I even went to the Chrysler dealer, as the thermostat is a Chrysler part, and the Neon gasket is close.....but not close enough ![Frown](https://www.northamericanmotoring.com/forums/images/smilies/frown.gif)
Read this before asking more questions!
https://www.northamericanmotoring.co...at-change.html
Then order your T-stat from Way because he shipped mine lightning fast!!!!
I am bumping this up because it appears that RockAuto now carries the gasket only:
http://www.rockauto.com/catalog/moreinfo.php?pk=4006716
PSIChocolate
08-13-2015 12:46 PM
