DTC, brake, seatbelt & Airbag lights all on, help. :(
Hey guys, I really need some assistance. After installing my new steering wheel (not a JCW, just a new oem replacement i bought off eBay) and re-connecting the airbag, my MINI tripped out. DTC, airbag/seatbelt, and brake lights ALL shot on. In addition to these issues, my car keeps 'going' left while in a slower speed (not leaning, not an alignment issue, but actually turning itself all the way to the left). Lastly, when the key is in the ignition, the windshield wipers will come on!!!
I'm really worried this could be quite expensive to fix... Especially with college coming up (not too much extra cash laying around).
Hopefully someone with some insight can offer some help,
Thank you,
Bradley in LV
Thank you,
Bradley in LV
Well, I'm not sure I'm going to be a lot of help to you. I seem to remember reading that when the airbags are disconnected, then reconnected, the "fault" lights needs to be cleared by the dealer; not certain if the other warning lights are related, but it wouldn't surprise me.
Nothing but speculation to offer on the rest of it; sounds like something might have gotten cross-wired or shorted within the steering column when you reconnected everything...?
Perhaps replacing the new steering wheel with your original might alleviate some of the issues? At least that would be a way to potentially isolate the problem (i.e., if some or all of them go away by returning things to the original configuration, the problem might actually be with the steering wheel you bought). Regardless, though, you'll still probably need to make a trip to the dealer to get the light "faults" cleared -- or just live with them. And they'll probably charge you some shop labor for the privilege of helping you out...
Good luck!
Good luck!
^Thank you for the reply Tim. I am going to try a few other things before I resort to the dealer, but I figure that will end up being the place to finally get this resolved. I am going to do is switch the steering wheel as you suggested, however I doubt that will rid me of the lights. The airbag and steering wheel both have very different connection spots, so both send off different warning lights.
Just a guess here but something has disrupted your SZL module, the steering wheel angle sensor located right where you plug in the airbag. The EPS (electric power steering) looks at that module and that would explain why it is turning by itself. You may have killed that module, or it may just need a reinitialization of the angle.
Like other responses, sounds directly connected to steering wheel
Yes, try reversing that.
Meanwhile, I ran into what sounds like a very similar issue when I installed JCW gauges. That required disconnecting a connector on the back of the steering column, which in turn presumably meets up with the wheel, as well as the signal and wiper switches. When I went to start/drive car, variously the wipers wouldn't turn off, only one side of the turn signal worked, many warning mights activated, etc.
Good news was once I finally got that connector and its locking clip seated right, all was well, everything worked, and all warning lights went back off.
I installed a JCW wheel last night by chance too. Transferred the steering wheel controls and wiring over. Did disconnect battery while doing it to avoid any airbag light potential issues. Went together fine, and no repeat of my prior electrical maladies described above.
07-16-2020 12:54 PM
quality_sound
08-07-2015 09:36 AM
