Clutch survey. How many miles on your Mini/other clutch.
Old 03-06-2011 | 09:52 AM
5zero4's Avatar
5zero4
So I like many others are at 38K miles and have a slightly slipping clutch. No noises, no grinding, just slipping with throttle in 6th gear mainly.
I know some have had clutches go way earlier, but how many have had no problems past 50K miles?
I was told by my SA that 35K miles is normal for a clutch? Yeah right!? I have only had 2 cars previous (both Corolla's) and never had one need a clutch within 90K miles. I owned one for 8 years and replaced the clutch once at 130K and then never again till it was totaled at 242K (still on the original engine).
If you all could take the time to fill out this survey it would be greatly appreciated. Any make/ model is welcome as long as it was a manual transmission. Even if you never had to change the clutch while you owned it please put down the mileage when you sold it.
If you have had a clutch replaced with an aftermarket one please include a short review and mileage done on that clutch.
I will start the ball rolling.
Model: Cooper S Hardtop
Year: 2007
Mileage at failure start/ Mileage when Replaced:
35K/ at 39K not replaced.
OEM or Aftermarket clutch:
OEM
Symptoms during clutch failure:
Slipping higher gears mainly, hasn't gotten worse yet.
Stop go city / Open highway / Hard driving RATIO
: 50/45/5
When replaced, what was the prognosis? Part Failure? Normal wear?: Not replaced yet.
Thanks.
Old 03-06-2011 | 10:39 AM
Flyinace2000's Avatar
Flyinace2000
Year: 2007 (lease turn in)
Mileage at failure start/ Mileage when Replaced: N/A - Turned in Lease at 2 year mark w/ 30k miles on car. Clutch was ok.
OEM or Aftermarket clutch: OEM
Symptoms during clutch failure: N/A
Stop go city / Open highway / Hard driving RATIO: 50/45/5
When replaced, what was the prognosis? Part Failure? Normal wear?: N/A
Year: 2009 (current)
Mileage at failure start/ Mileage when Replaced: N/A - Currently at 25k miles with OEM clutch still ok.
Stop go city / Open highway / Hard driving RATIO: 35/60/5
Old 03-06-2011 | 11:11 AM
5zero4's Avatar
5zero4
Thanks.
So even with an AP tune you have nothing yet. I had an RMW tune for a couple of weeks, and the day it was put on I really noticed the clutch slip in 5th and 6th (too much power for it!!!!)I had to get it removed while I save for a new clutch. I will be interested to see how yours goes.
Edit. Sorry I saw that the AP it not installed yet. Anyone else with an AP?
Old 03-06-2011 | 12:01 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Model: Cooper S Hatch
Year: 2006
still no problems, 67,000
No failure
: 65/30/5(track and auto-x)
When replaced, what was the prognosis? Part Failure? Normal wear?: Not planning on replacing any time soon
Old 03-06-2011 | 01:51 PM
veggivet's Avatar
veggivet
Make: MINI Cooper R 50/Scion xB
Year: 2002/2005
Mileage: 72,000/92,000
Driving style: 1/99/0
No problems on either.
Old 03-06-2011 | 01:54 PM
slinger688's Avatar
slinger688
Model: Cooper S Hardtop JCW Stage 1
Year: 2008
Clutch OK so Far at 32 K Mikes
OEM
Stop go city / Open highway / Hard driving RATIO: 10/70/20 (32 track days so far/1 AutoX)
Old 03-06-2011 | 04:26 PM
jcauseyfd's Avatar
jcauseyfd
Year: 2008
76k miles - no problems
None.
: 15/70/15
Old 03-06-2011 | 04:35 PM
Floor-is's Avatar
Floor-is
Year: 2005
Mileage at failure start/ Mileage when Replaced: 64k miles - no problems
Symptoms during clutch failure: None.
Talked to someone today driving a Just a: 140k on it, still driving the factory clutch
Old 03-06-2011 | 04:51 PM
nicknbecka's Avatar
nicknbecka
Year: 2007
127K, not replaced.
OEM
N/A
: 20/80/5
Old 03-07-2011 | 06:03 AM
Mini_Voyager's Avatar
Mini_Voyager
Motorholic
Year: 2007
Mileage at failure start/ Mileage when Replaced: 40K (now in shop)
Symptoms during clutch failure: Racing engine in lower gear, finally couldn't move even on gas.
Stop go city / Open highway / Hard driving RATIO: 70/20/5
When replaced, what was the prognosis? Part Failure? Normal wear?: "Normal wear and tear"
Old 03-07-2011 | 06:56 PM
hoonu's Avatar
hoonu
Model: Cooper Clubman
Year: 2008
Mileage at failure start/ Mileage when Replaced: 49K/ Appointment in a couple days to evaluate
Symptoms during clutch failure: Chatter when engaging from a stop, forward or reverse. No slip, no problem during gear changes after moving.
Stop go city / Open highway / Hard driving RATIO: 10/90/0
I'll echo the sentiments expressed by the OP: I've had cars with many, many, many more miles than this, and have never replaced a clutch on anything. I'll keep you posted as to what the SA/tech tells me.
Old 03-07-2011 | 07:06 PM
Johnna's Avatar
Johnna
oops. just noticed this is a 2nd gen forum, just disregard.
Year: 2005
Mileage at failure start/ Mileage when Replaced: Still going strong at 89K
Symptoms during clutch failure: No simptoms.
Old 03-08-2011 | 05:41 PM
Richieb0y28's Avatar
Richieb0y28
Model: JCW Hardtop
Year: 2010
12k miles, no problems
OEM
N/A
Stop go city / Open highway / Hard driving RATIO: 60/30/10
Old 03-08-2011 | 06:26 PM
sequin's Avatar
sequin
Model: Cooper S Clubman
20k miles, no problems
Stop go city / Open highway / Hard driving RATIO: 60 / 25 / 5
Old 03-08-2011 | 06:36 PM
ballandchain's Avatar
ballandchain
Model: Hardtop S
Year: 2009
Mileage at failure start/ Mileage when Replaced: 20k miles, no problems
Stop go city / Open highway / Hard driving RATIO: 80/15/5
*******THIS IS ABOUT THE ONLY THING THAT HASN'T BROKE YET*******
Old 03-15-2011 | 07:08 PM
5zero4's Avatar
5zero4
Year: 2007
127K, not replaced.
OEM
N/A
: 20/80/5
WOW!!!!
And the winner is....
Old 03-15-2011 | 07:09 PM
5zero4's Avatar
5zero4
Year: 2008
Old 03-15-2011 | 08:59 PM
xsmini's Avatar
xsmini
Just over 250,000 and still on the original clutch.
Nik
Old 03-15-2011 | 09:08 PM
5zero4's Avatar
5zero4
Nik
On what vehicle pray tell?
Old 03-15-2011 | 09:42 PM
xsmini's Avatar
xsmini
03 Cooper S
Old 03-16-2011 | 10:44 AM
ThumperMCS's Avatar
ThumperMCS
Clutch 1:
Model: Cooper S
Year: 2008
Mileage at failure start/ Mileage when Replaced: 30kish / 30kish
Symptoms during clutch failure: Really weird engagement, jerky. Clutch itself was fine, no slippage.
Stop go city / Open highway / Hard driving RATIO: 75/25/and I'd say 50% of my driving is hard driving ...also have had a tune since just before 30k miles, and a bigger turbo for the past 10k miles.
When replaced, what was the prognosis? Part Failure? Normal wear?: Throwout bearing/pressure plate/flywheel issue (don't remember the exact issue to be honest)...clutch was still within spec. But all parts were replaced under warranty...clutch included.
Clutch 2:
Mileage at failure start/ Mileage when Replaced: 51K / current issue, not replaced as of yet...
Symptoms during clutch failure: Rattling flywheel at idle, stops when clutch is pushed in. Clutch holds fine though, no slip. Even with ~260 ft-lbs to the wheels.
Stop go city / Open highway / Hard driving RATIO: see above
When replaced, what was the prognosis? Part Failure? Normal wear?: Taking it in Thursday.......
Old 03-16-2011 | 11:30 AM
wpb mini's Avatar
wpb mini
Year: 2007
Mileage at failure start/ Mileage when Replaced: 35K/ at 39K not replaced.
Symptoms during clutch failure: Slipping higher gears mainly, hasn't gotten worse yet.
Thanks.
make/model/year: 2005 Infiniti G35
OEM clutch
mileage at start of symptoms: just over 50K
symptoms: slipping for G35
mainly stop and go driving-65 or 70 highway, 30-45 city
clutch not replaced; opted to trade in car instead of repairing
prognosis: normal wear.
I also had an Infiniti G20 that went over 50k miles before needing clutch replacement. I replaced it with OEM clutch just before I sold that car at 70k miles.
Old 03-16-2011 | 04:09 PM
gregsmini's Avatar
gregsmini
Year: 2008
30k
OEM
N/A
:40/55/5
Continues to be fine. I've never had clutch issues while driving pickup trucks to 18 wheelers for thirty five years. I hope to keep it that way!
Old 04-06-2011 | 08:01 PM
5zero4's Avatar
5zero4
Well... I took my Mini to Universal Mini today for an "excessive battery discharge" message. They asked if there was anything else I wanted them to look at. I mentioned a weird "sigh" or "hoot" noise when taking off from a standing start. They came back with it being the clutch and said they could have it done by tomorrow. I asked how much, expecting to hear the $3000 price tag. They said "NOTHING!!!!!" under warranty!!!!!! WOW!!!!
Needless to say I said go ahead. Very happy about that one.
On a side note, I have a 2011 Hyundai Sonata rental, and it is pretty sweet. Much better than my Mom's Hyundai Excel from many moons ago. Hyundai have really picked their game up. But still nowhere near as fun as the R56S!!!
Old 04-07-2011 | 03:05 AM
009Mini's Avatar
009Mini
Year: 2009
Mileage at failure start/ Mileage when Replaced: 67,000 miles no slipping or other wear signs. I hope it lets go before the 100k maintenance plan is up.
Stop go city / Open highway / Hard driving RATIO: 50/50 all with brisk acceleration
Quick Reply: Clutch survey. How many miles on your Mini/other clutch.
