Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Does anyone have experience with changing the A/C compressor? Are there any specialty tools, DIY tips/steps, or things I need to know? I'm pretty handy and have access to a lift.
looking for the same... any tip of getting the top compressor bolt out?
That one was a pain in the ***!!!
I took the idler pulley, that made it much easier to see.
I ended up using my small torque wrench (in-lb), for handle length and a deep 13mm socket. It was a perfect fit and cleared the alternator.
When I removed mine (A/C delete), I just removed the bumper and unhooked the upper rad hose to pull it away. Did the same to replace the alternator as I wasn't willing to waste my time struggling to remove a 4 bolts or get the alt/compressor out in a limited space.
Keep in mind it is illegal and immoral to improperly dispose of A/C refrigerant if you are not both ASE certified and using a proper evacuation machine.
