Chatter? What is this i hear?
Ok, got a 2005 cooper s. 99,000 miles. Noticed a soft chatter while sitting under my carport. Can't really tell where it's coming from... Doesn't do it all the time either. Every few times I take it out. Thing doesn't get drove much. Anyway, Went to back out of the driveway... Mashed the clutch to throw it in reverse and the chatter went away... Every time I hear it, i can mash the clutch and make it go away. Sometimes it comes right back, but most of the time not. Leads me to believe i may have a clutch bearing on its way out. CAN ANYONE CONFIRM? And, now what should i expect? Shifts just fine. Other than the faint chatter every once in a while, Can't even tell. Anyone had a similar issue? Thanks in advance...
Mine makes chatter noise sometimes when in neutral. It's kinda normal transmission noise, just more noticable on our cars.
If you push the clutch in it should go away. Let the clutch out slowly in neutral and it probably won't make the noise.
I have a good friend who rebuilds transmissions, he listened and said it's absolutely nothing to worry about.
Throw out bearing only turns when the clutch pedal is depressed. A noisy bearing will only be so when turning. In neutral the transmission is turning when the motor is running. Depress the clutch in neutral with the motor running and the transmission will stop turning. The noise you hear is the transmission turning.
I had the same problem, it's either the dual mass flywheel, the throw out bearing, or both.
No matter what anyone says, this is not a normal sound. It will only get worse with time.
A new dual mass flywheel from the factory can run $700 - $900 depending on where you live. A new clutch is not included.
Valeo makes a single mass flywheel conversion kit that includes a clutch that can be picked up for inbetween $600 - $800 depending on where you live.
Be prepared for major sticker shock on the labor to have it installed.
Miniwaukee
09-29-2015 09:22 AM
