Help with Alternator problem.
Ok,
I have been working on this problem for about a week now. I will give you some background. I had a low oil pressure issue and lost the motor back in NOV. I have started replacing the motor, got it in. I replaced the clutch while it was open along with the flywheel. Now, I have a problem where the alternator will not charge the battery. I am getting 13.5 to 14 volts off of the alternator, but when I attach the cable to the alternator that comes from the harness, I get nothing. I also get an open loop when I do a connectivity test with the multimeter.
Now, does anyone now how this electrical connection routes, or do I need a new harness? Where is the other end of the alternator cable?
Thanks,
Bryan
Thanks,
Bryan
daviday
09-25-2015 01:31 AM
