2003 MCS Instrument Lights Stay On
Old 03-26-2011 | 07:16 PM
Mac2003's Avatar
Mac2003
My instrument lights don't turn off when switch is turned off or when car is off. Help.
Old 03-28-2011 | 06:49 PM
MoB-NorCal's Avatar
MoB-NorCal
Same thing happened to me today, I had it happen a bit ago
Took the mini in and the said it was all fine, happened again today at school, But somebody had jumper cables so I could at least get it home.
My car is an 05, I'm puzzled
Old 04-03-2011 | 06:41 PM
cfb8960's Avatar
cfb8960
I just had the same problem. I reset ECU. google it, (there are simple instruction with the ignition key and tip reset button, really). And I disconnected the battery for 10 minutes and put it back. Now it works. Make sure you have radio code. Good luck.
Old 04-03-2011 | 06:43 PM
cfb8960's Avatar
cfb8960
Here you go, I found it.
With the key in the ignition, but in the off position, press and hold down the odometer reset button with one hand, while holding the button down, switch the key in the ignition to position 1 (first click) with the other hand.
The screen will have a number and the word “tESt”.
Scroll through the numbers by pressing the odometer rest button, through to 19 and wait a moment. (Note: the number order is: 1,2,10,19)
The message will say 19 "L i-off", flash to "L i-on", and back to "L i-off" again. When "log i-off" appears, press the odometer rest button again. You are now in the system.
Scroll through to 21. tESt and wait a moment. 21.0 rESEt will come up. Press the button once.
Your gauges will now make some sounds and movements. Once the lights come back on start your car. You have now reset your ECU and your MINI is now ready to relearn the new mods and your driving style.
sevin
02-01-2016 12:30 PM
alistaircookie
10-08-2015 11:52 AM
PrimePower
08-16-2015 07:29 PM
oldkid6
08-11-2015 09:13 PM
PrimePower
08-11-2015 01:51 PM
Quick Reply: 2003 MCS Instrument Lights Stay On
