Fast blinkers
Fast blinkers
Does anyone else have this problem? I had some after market bulbs in my blinkers, front and back for two and a half years. Everything worked great and then all of a sudden one day I'm getting the bulb out warning light, took it in to service and they suggested replacing the bulbs to the OEM ones. So today I replaced all bulbs back to stock and still getting fast blinker. And bulb out signal.
I'm not too sure about your conclusion there. If something is "burned out" then its an open in the circuit. If something is shorted out by a frayed wire it will maybe cause it. But as far as "current flow", electricity doesn't act like water in a hose. Especially A/C current.
Also, buy a "frayed" wire, I meant that it was open, not shorted.
on
There are three bulbs you need to check on each side:
Front blinker bulb in the headlight assembly
Side scuttle bulb
Rear blinker bulb in the taillight assembly
If those all seem to be working then find my post that explains getting the detail of the check control message you are seeing, it will drill down a more accurate description of your error message and hopefully pin point the problem.
Side scuttle bulb
Yes I have checked all three on each side and all seem to be ok. Now this is weird but when I turn on the emergency blinkers they blink slow or normal. When I then click either side blinker it still blinks slow. but when I turn off the emergency lights they blink fast. I hope this makes sense.
on
Sounds like either a bulb socket or wiring has been damaged.
And the worst case scenario is your FRM module is now damaged from the LED use. I have discovered that retrofitting any light bulb in the car can be a very risky thing to do as the FRM is directly wired to each and every exterior bulb. The computer expects a certain load and resistance on each circuit and of course does warm and cold checks on each bulb and light.
Well my issue with the fast blinkers is ongoing, I took the cooper in to service and now they are saying that I should replace the battery and or the the altenator. The tech said I was not getting 14 volt output, I measured myself and found 14 volts! I don't know what he was measuring. The battery has a green full charge indicator. They also said that I should unhook my sound system, amp, Cleansweep etc. it may be to much of a load on the altenator. I know several people have aftermarket amps in there Coopers with no problems so I pretty sure that this is not the problem. Any more advice would be greatly appreciated!
The FRM module is really a computer that controls a lot of things as well as the lights. and from what you have explained with the double flashers and that working right and then when turning the double flashers off it not working correctly it sounds as if you have a corrupt FRM module.
Try disconnecting the battery for at least 30 minutes. That should reset the FRM module programing and hopefully correct you problem.
Let us know how it works out.
If that does not work have the dealer do a complete reinstall of all software in the car.
Many things are corrected, like window dip problems, Heat A/C problems and such by a full reprogram.
Ok, I disconnected the battery for 45 minutes, hooked her back up got in and started it up. Tried the blinkers and for the first 3-4 times it was back to normal but then went back to fast blinking. Pissed! Is there any way of knowing which bulbs are giving me a problem, like I said previously it gives me two light bulb errors and a rear fog light error.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
