A/C inop and fans not working... Please read
Old 05-24-2011 | 12:23 PM
Cadenza's Avatar
Cadenza
Originally Posted by turbostang52
Thanks Cadenza, I will definitely check out the pressure sensor as well.
I may end up replacing the compressor but just want to be sure it's not something else (like the pressure sensor) that isn't allowing the a/c compressor to kick on.
The pressure sensor feeds a signal to the ECM. If there's not enough pressure or the sensor is stuck open, the ECM will not activate the AC relay.
You could remove the wiring harness from the pressure sensor and jump the wires. This fools the ECM into thinking there's enough pressure and activates the AC relay when the AC switch is turned ON. (Technicians have done this to intermittently activate the AC so they can recharged the system.)
BTW, there's no schrader valve at the pressure sensor. Remove it if you know for certain it's faulty.
Filmy
15
06-06-2023 07:27 AM
patsum
26
05-29-2021 07:29 PM
Quixotic1
09-11-2015 12:15 PM
Ntety
09-02-2015 09:39 PM
doug5g
09-02-2015 05:53 PM
