Tensioner Stop Cable Breaking?
I had a 15% pulley installed a couple years ago at AMVIV and as part of the install, a tensioner stop cable was installed as well. See below:
When I had the belt replaced last year, the mechanic noticed that the cable had snapped at the grommet end. I ordered another and had it replaced.
I was checking out some things under the hood yesterday, and I noticed that the new cable has also snapped at the same location; the belt seems fine. Other than the possibilty that I got a bad cable (twice), what could account for this? I tracked the car four times last season, and plan to do at least that much again this season.
Last edited by Claymore; 04-22-2011 at 09:16 AM. Reason: .. Mods - please move to the Drivetrain (Cooper S) forum
Mine snapped also, so you are not alone. Same place, right where it ends. I am thinking there is a lot of micro flex going on at that one place rather than along the entire length as the designers imagined. On a side note, even though the tensioner had snapped and the spring keeper had snapped too (the thing you put a wire in to hold the tensioner off the belt) No catastophic failure was experienced. In other words, the tensioner failing doesn't always make for a damaging situation. My old one came out in pieces and I was just replacing it because of the mileage, I didn't know it was bad.
patsum
26
05-29-2021 06:29 PM
cdemarco4
09-10-2015 10:14 AM
wildwestrider
09-04-2015 06:25 AM
