Gas Pedal - gone bad or not bad? I dunno!
About 6 months ago I was running up an on-ramp and got a SES light. I used the diagnostic mode in the odometer to find that it was showing P1122, which apparently is Pedal Position 1 Low Input, and seems to mean that the voltage coming out is too low. Nothing bad seemed to be going on so I just let it go...
Of course, I need to get inspected to renew my tags so I went ahead and bought a new (used) acclerator pedal, and it hasn't fixed the problem. I tried a few on/off cycles and also did a software reset via the diag console, to no avail. It's still giving the same fault code, so that's good I guess. At least I didn't make a new one!
The fault occurred about a week after I changed the LCA bushings, but I really have a hard time belirving that's related. A year prior I did the waterpump gasket and actually forgot to plug in the throttle body sensors and all Hell broke loose, but that's a whole different set of codes so I don't really think there's anything there either.
Unfortunately I don't have a Bentley (yet?), so once the wires disappear into the underdash I have no idea where they go, or what pins do what. I assume the other end is on the ECU. Can anyone give me a hint here?
Welp, I got my hands on a scanner and cleared the code. Then it came on again. The diag console still says I have an 1122, but the scanner says it's P2096. Based on a quick forum search, I may have a PITA on my hands. I'm a little concerned that the two codes are different. The scanner is one of those cheapy ones that run about $30, but a friend of mine had it and lent it to me. Ah bugger, it's beer-thirty now.
Camden90240
09-28-2020 12:09 PM
thadscottmoore
09-25-2015 10:07 AM
wildwestrider
09-04-2015 06:25 AM
