Noisey LSD getting worst..
![Impatient](https://www.northamericanmotoring.com/forums/images/smilies/impatient.gif)
I changed MTF94 to Redline MTL 5k miles ago.. lately the noise from lsd getting worst, specially at low speed, and sudently noise compeltely dies when i right corner it with 30 some mph... Confused
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
any suggestions would help.. thanx in advance
Its factory LSD.. I just filled with the right fluid ( from mini of dallas) and the car is still very load at slow speed (20 mph) and the car has alot of vibration. Im thinking to drive this on high speed (70 mph) and see if it reduce noise and vibration?? Or better not and take it to machanic..
I would check the LSD to determine if it is still working. To do this, go to a secluded road with a gravel shoulder. Put one front wheel onto the gravel and the other on the pavement. Quickly accelerate the car from standstill. The gravel wheel should spin and the one one the pavement should grip, then the spinning wheel would grip as well. If that is the case you have LSD.
09-28-2015 09:13 AM
