03 MCS Headlight Bulb
you gots a problem . . . .
most often the problem is the ballast
but you are not going to find a simple solution at the local AutoZone
go to the dealer and keep one hand on your wallet
ain't them fancy headlights neat??????
First step....just swap the bulbs left to right....if the problem follows the bulb, great. If not, then the ballest or the ignitior is most likely bad.
XENON lights, especialy the projectors are great...the others are still pretty good....the long bulb life is nice too.....just buy a quality bulb....the cheapy ebay ones are a low grade....and you will not be a happy camper.....
can i just buy a 55w HID kit from DDM Tuning and put those in with new ballasts??
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
You might need to fab up some parts....the kit is made to fit into a halogen headlight...so the bulb mounting is likely different (the kits bulbs will have a different base), and the wiring is made to plug into halogen wiring..(usuallu from the bulb plug), you don't have that either to plug into....might be more trouble than it is worth imo....
You need D2R HID bulbs to replace your factory ones. I only recommend buying genuine Philips bulbs through a trusted vendor, or Morimoto D2R bulbs. I get all my HID components through Matt at http://www.theretrofitsource.com. If your ignitors are good (swap bulbs L/R to check) then you'll probably benefit from a set of new bulbs since HID bulbs do lose output over time (although rather slowly).
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
07-16-2020 12:54 PM
dyeLucky
08-07-2015 07:10 AM
