Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
So the mechanic I took my car to years ago stripped the bolt that hold the rotor on the front right. The only way I can see to get it off is to drill it out. My question: can I drive without that bolt or will the cause problems?
The bolt can be drilled out and removed using an Easy Out tool.
When you replace the bolt, put a little antisieze on the threads.
It will make it easier for the next tech that has to work on it.
I buy things like that since they are cheap and if ever you are right there, feel like messing with it, you have the $2 part if you can get the old one out. If not, sooner or later when you buy new rotors, you will have one.
What's the thread size for a thread chaser? I snapped the head on one today. Drilled it out down to the threads, and put the new bolt in my cup holder.
