Creaky clutch pedal or cable or something?
Hi all
Mini convertible (no s) Sept 2004 delivery, 2005 model year, 5 speed manual.
52k miles, most of them local (so a higher than average amount of clutch use)
parked next to a wall today with the window down and I noticed a sort of a creaking noise when I depress and release the clutch, in gear or out. The noise may have been there for awhile now, but i didn't notice it until i was next to something for the sound to bounce off of. Not too loud, but i want to get ahead of any serious problems.
It sounds like the noise you might imagine from a rusty spring or wire going over a pulley or a dry hinge. a low volume short mechanical creak. I'm guessing it's a cable or pulley associated with one of the clutch pedal components.
I'm hoping this is a common, easily diagnosed issue and someone here can let me know if it's a big deal or not, where to look, and what the probability is that it is what they're suggesting.
thanks
Eric
thanks
Eric
Just got an email from the dealer:
The clutch assembly uses plastic parts that can sometime cauase that noise. Usually we just lube it and its fine but I would like to still inspect it to make sure there aren't any faulty parts. Would you like me to set up an appointment?
I asked her to give me a ball park location for these components so i could check them first. Will post if i get anything useful back.
thadscottmoore
09-25-2015 10:07 AM
09-16-2015 06:22 AM
09-16-2015 06:18 AM
wildwestrider
09-04-2015 06:25 AM
