Having trany problems..HELP...
Hello, Rob here....
Im a new Mini owner, purchased an used 2005 Cooper about two months ago and I love it! All was going well untill a few weeks ago; I started having problems with 5th gear.
The problem is that when I would shift into 5th, it would pop back out of gear and make a grinding noise. It continued to get worse and is now doing the same thing in 4th gear.
I have parked the Mini untill I can figure it out and correct the problem.
Has any one had this problem? Im thinking it has something to do with the shift cables....
on
I agree that it sounds like synchros have gone out.
Positive way to check it, drain transmission oil and look for metal pieces in the oil.
The R50 is fitted with the 5 speed Midlands transmission that is not very dependable or reliable after 50K.
If your transmission is shot, I would recommend installing a 05/06 Getrag 6 speed transmission instead of another Midlands.
on
I read on another board the change was with the July 04 builds.
on
Midlands until 7/2004
Getrag 5-speed from 7/2004 - 9/2006.
They take different gear oil, too - (ask me how I know).
https://www.northamericanmotoring.co...ion-fluids.pdf
Oh well, metal in the gear oil, I’m thinking my next step is to contact the BMW shop that the transmission was purchased from and see if it is under warranty.
Also I did a little more research and found that after July 2004, the getrag five speed gear box was used. My Mini was built in April 2005.
jackfl21
05-29-2013 09:29 AM
djyco
07-03-2005 06:21 PM
