Help with a/c...
on
Help with a/c...
So my a/c will not blow cold at all.
When I turned ac on the clutch would not spin on compressor.
Today I replaced my fan, dryer, and ac compressor.
Checking with a/c gauges there are no leaks.
Attempted to recharge the system and the system equalizes with the can of freon, it will not take anymore [its def not full] and the compressor clutch will still not spin.
Should I replace the hi/lo switch? that is the only thing me and my tech friend can figure may be the problem.
Since its a pressure system, there are conditions where a switch needs activated on the high or low side to allow the new coolant to be circulated. I believe the ac clutch is also pressure activated, so if the line pressure conditions aren't right the pump would not activate.
I don't know what these conditions are how to fix or any much more than that.
Just stuff I've seen researching a temperature problem on my neon (which I fixed when dropping in a simple ac relay fuse only after a thermostat, temp switch and ECU).
The neon guys seem to reccomend professional attention rather than the bottle kits suggesting they can do more harm than good, don't know why.
ArchiMark
16
05-18-2007 06:45 PM
