Whining noise in the front
Old 06-10-2011 | 09:00 AM
cschues80's Avatar
cschues80
So i noticed the other day that my mini has a whining noise at around 30 mph when im on the throttle( not coasting) its not at an rpm where the turbo would start to spool either. So is this normal for a mcs? I figured if its not then it should be something in the drivetrain. Any input? And if anyone has had this problem what fixed it? Im at just under 59,000 miles on my 07
Old 06-10-2011 | 10:13 AM
slimjimtell's Avatar
slimjimtell
Where is the noise coming from? Pinpoint a location...under hood, under dash?
I just got mine fixed for a whining air compressor. It would whine under throttle and sounded like it was behind the passenger side dash.
Sit in your car
turn on AC
set fan at lowest speed
Press trottle until RPM is up around 2500-3000
Is it whining???
While still under throttle, turn AC off
Did it stop whining?
If so, it's the compressor.
There is a TSB to fix this with a counterweight under warranty.
Hope this helps!
Old 06-10-2011 | 11:00 AM
cschues80's Avatar
cschues80
As far as I can tell its under The hood. Deff not an a.c compressor. But only happened when I'm in gear with my foot on the gas and the noise starts at 30.
Old 06-10-2011 | 11:24 AM
///Mflossin's Avatar
///Mflossin
Sit in your car
turn on AC
Is it whining???
Hope this helps!
Interesting. THanks for posting this. I often wondered why the car was so loud with the AC on.
Old 06-10-2011 | 01:51 PM
Spridget's Avatar
Spridget
We used to get a whining noise from the back seat area. It sounded something like, "Are we there yet?"
Spridget
Old 06-11-2011 | 07:24 AM
cschues80's Avatar
cschues80
Haha, spridget, hope I don't get any of those
Old 08-22-2011 | 04:04 PM
biggripper's Avatar
biggripper
I've noticed this recently. It seems to be present with the AC on or off. Only really noticeable at relatively slow speeds/low RPMs. I'll keep an eye on it.
Old 08-23-2011 | 10:48 AM
pheatton's Avatar
pheatton
Yep same here, dealer cant seem to pinpoint the issue.
Old 08-23-2011 | 01:03 PM
Korben Dallas's Avatar
Korben Dallas
Is it RPM dependant? I hear a whining constantly throughout the rev range. Sounds like an M3 GTR racecar, but subtle.
KrisMiss
01-03-2016 02:02 PM
damncajun
08-17-2015 08:25 PM
elightbo
08-17-2015 01:50 PM
Powershift
08-16-2015 05:14 PM
FLYM1N1
08-15-2015 11:20 AM
Quick Reply: Whining noise in the front
