Starting problem after several days
Have a problem starting my 09 MC (Auto/tiptronic) after the car sits several days.
Insert the key fob and indicators come on but brake is stiff and ignition does not respond. Display area 2 shows a "key". Tried the other remote with same result. The after several tries, re locking doors etc. It works! go figure???
Is there a pause or delay where new data is being reset in the remote? Once it starts first time it does not re-occur. And does not seem to happen when driving daily. But has occured each time the car has sat unused for several days. Battery?? Once the ignition works there is no indication that the battery is discharged (it fires up quite normally)
Feel I've been lucky to get it started last couple times. Any ideas?
Also of note is that CA cars the battery DOES NOT charge. It is a replaceable button battery.
Non-CA cars do have a rechargeable battery.
Thanks for the thoughts. Do not think it is FOB related as BOTH FOBs would not start the car, and when it did finally start, either FOB worked. Spoke with dealer and he suggested 1) Battery could be failing, but they'd need enough time with the car to see the problem; or 2) It may just be taking some time for the FOB and car to recognize each other and transfer data after several days. He suggested to insert the FOB and wait a minute before starting. I'll try 2) next time and hope its just a slow to wake up issue. Thanks for the input!
As for needing time with the car. NO they can check for a failing battery with a battery tester and that only take a few minutes. Take the car or battery to most auto parts stores and they can check it for you.
If this does work then the dealer needs to replace a module or two in the car under warranty as this should not be happening. They should wake up and be fully functional in less than 5 seconds.
GOod luck with figuring this all out.
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
skippermini
08-13-2015 06:13 AM
