2011 MCS more problems! NOW: clutch and gear shifting noisy..
Hey peps..
So, sine I bought my car in April 2011, it has already been to dealer twice.. Now, I noticed a new sounds and problems.. I am not sure yet, if this is any serious or not.. I wouldn't be so afraid, if I had dealer "next door".. but it is over 100 miles away (one way) and it takes me entire day to take off from work, and take my car there to have it checked..
This time I noticed a noise coming from clutch area.. It happened few times so far, especially when it is hot outside and kinda humid.. today was 90F and mid humid.. Here is a video of the noise.. car was parked in garage, engine was off, I made about 30 min trip from work.. AND YES THATS MY BLUE LEDs - no comments please
CAR only has almost 4000 miles. Driven in city mostly with maybe 1500-2000 on highway so far..
Also, while U watching that.. there is a part of the clip showing how rough is my gear shifting.. I would expect little bit better from brand new car. When I took it last time to dealer.. they told me it was normal (gear shifting).. and the car did not broke in yet. You be the judge:
here is from the other day:
Your gear shift is fine. It's a sporty car and it comes with a notchy shift pattern. I added a short shifter to make it MORE notchy.
The clutch noise doesn't sound very bad to me, it sounds like what I would expect a hydraulic system to sound like. Push the brake with the car off and you will near noise as well.
Can you tell where the clutch pedal noise is coming from? Some in the pedal itself or more toward the engine bay?
I had to have mine lubed at the hinge point when it started making a squeaking noise. The noise only started to manifest itself when the car got warmed up and it was hot outside.
did U have to take it to dealer or did U do it by yourself?
thanks for Your input guys.. make me feel better about my gears
Mine was definitely coming from the pedal mechanism itself (which is why I waited to have it addressed instead of making a special trip). iirc, if the noise is coming from the engine bay, it is indicative of some spring or linkage that either needs replacement or adjustment.
In any case, based on the video you posted, I would definitely say the noise is not normal. I don't think moving the clutch in and out like that should make any sound.
on
You might want to peruse this thread regarding the clutch pedal squeak.
The shifter sounds normal to me as well.
I don't mean hijack this here thread. Ignore if totally unrelated, but I hope it informs topic.
I'm new to Minis and I found certain noises it made peculiar and worrisome. The sound is different from yours and it occurs when the clutch engages, but nevertheless, it involves the clutch. I posted my concern here: https://www.northamericanmotoring.co...-engaging.html
To summarize, the members who chimed in assured me that the noise I hear when the clutch engages is "normal."
Oh, and I get that notchy sound from my shifter, too.
and the only reason I got rid of my VW Rabbit.. got close to warranty expiration.. as well as I got bored with it.. and now I have 2011 Mini Cooper S and monthly trips to dealer.. OH BOY :/
My clutch actually makes that same noise when it's warm/hot outside (that squeaky noise) which is pretty much everyday here in san jose. My friend with a s2k says his clutch also does this when the weather is warm/hot outside so that put my mind at least for the moment. In any case let us know what the dealer finds out.
I am going just enjoy my car for now.. and see what the future will bring I simply do not want make every month app with dealer to bring my car. I'll wait till maybe like septemeber/october and see then.. As stated before, that squeaking noise from clutch is there only when VERY HOT and humid outside.. tonight got to upper 60's and there was no noise at all.. this weekend will be HOT again so we will see.. will keep You posted.
Hi guys! I am a MINI Cooper S (11/2006 r56) owner from Spain and I gonna tell you my history with the car.
It only has 20k miles and I had to replace the clutch yet. I didn't left the car to the dealer (or stealer better ) y I replaced the clutch in other garage. Well, I did not heard the noise before the clutch replacement, but I've been hearing it since the first day I replaced the first one. So, under warranty, the garage replaced my clutch again (2nd time)...And the noise still happens. So, I don't think it's about the clutch plate or similiar, I guess it comes from the pedal mechanism like someone explains here, post #2
https://www.northamericanmotoring.co...dle-issue.html
The kind of noise is similar to the related videos, and occurs when is hot outside and I've been driving some minutes. It isn't sound when the car it's cold.
Thank you guys, and sorry for my English
I don´t know how easy is to change that parts...
Sorry
Sorry
Heat expansion resulting in rubbing somewhere beyond the pedal? If it only happens on hot days that would make sense to me.
First video definitely seems to show some surprising sounds. My friends manual 2006 r56 didn't sound like that at all. As others have said, it's probably worth bringing in, just make sure it can be replicated for the 100 mile trip to be worth it.
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
08-12-2015 01:24 PM
Colt45Magnus
08-12-2015 06:43 AM
