valve cover replacement? Plugged PCV valve?
#76
#78
#79
As long as what you have can handle 250 F youre good to go.
#82
Yep pull that tab and replace it with the little new one that comes in the baggy
#83
#84
Where?
You can buy a new valve cover for $60 on the internet that bolt up perfect, no leaks etc. it doesn’t have mini stickers etc but for $300? Get a catch can. About $40 and PCV block off tabs ($20 from mini) and don’t keep messing with trying to fix something that was broken. The n14 prince engine has issued so either replace and change or you’ll have a lot of headaches! It’s stupid to pay $1000 for minor fixes for a $7000 car.
#85
Does anyone have an image or video (or even a description) of exactly how to pries the PVC membrane cap off the N12 valve cover? In order to replace it with one of these caps from @ECSTuning https://www.ecstuning.com/b-vaico-pa...127646554~vai/
#86
Hello Craney, This guy changed it: https://www.northamericanmotoring.co...patch-kit.html
#88
Welcome.
#89
On another note, ROCKAUTO lists this PCV valve on its website. STANDARD MOTOR PRODUCTS V459
Is there a second PCV valve for this motor?
http://www.rockauto.com/en/moreinfo....441103&jsn=312
I think that is erroneously listed for the R56 as this same part is listed for earlier R50-R53 at Way Motor Works:
https://www.waymotorworks.com/crankc...0-r52-r53.html
09R56
11-16-2022 10:49 AM
silence2-38554
98
09-21-2016 02:52 PM
