boost problems
boost problems
i have a boost gauge on my r53 and when im at 8-9psi boost the needle bounces rapidly between 7 and 9 psi. also when around 4500-5000 rpm the boost bounces from 0 to 5 psi. what can this be? maybe the bypass valve? when i reach 6000 rpm i can get to 10psi like it should. meaning theres no major boost leaks.
on
My Autometer boost gauge did the same thing with it tapped into the FPR line. What it is, is the gauges are really sensitive and it picks up the pulses of air out of the S/C rather than a constant pressure. The M45 S/C isnt verry efficent in the way it works and you willl always get theese pulses.
You can "fix" the gauge by changing your boost gauge line to a rubber hose, and tap it in to the I/C outlet horn. Its quite a bit of work to do this but if it bugs you that much...
Indimanic
08-19-2015 11:08 AM
Ambient Thermal Management
08-07-2015 12:27 PM
