Passenger Front Window Motor Issues
Hello all, my wifes 2003 mini cooper s front passenger side window just recently quit working. The unit gets power from the switch as it clicks as if it should work but there is no movement what so ever. THe window just stays up all the time. Any ideas on what this could be?
Amazing! Mine just quit working yesterday and a smack is all I did to bring it back after finding this thread!
Well, the passenger side window regulator was always not working too well after the first two years. It sometimes forgets to retract or extend when door is opened or closed.
In the long run, will replacing the window regulator help?
Happened again last night.
I smacked it 5 times, didn't work.
Then kept on driving, until I hit a regular road bump, it went back to normal.
I'm afraid that this is just temporary fix and will get worse in the long run.
What's the real solution? Can I open the door trim and rebuild/enhance it?
Fonzie method worked like a charm
I had to hit the door about 20 times and was worried what it was doing to my speaker, BUT...it worked! Thanks so much for the info!
07-16-2020 12:54 PM
12-23-2015 10:36 AM
