Oil change nightmare
Old 09-07-2011 | 09:13 AM
Erhan's Avatar
Erhan
Hi everyone.
2 days ago, I did an oil change using mityvac. The car is R56 Cooper S. I also changed the oil filter and put a new oring. After the oil change I started having leakage issues from the oil filter housing/cap during driving and idling.
A friend of mine, who's more skilled than myself, took a look, and decided that the cap might have been overtightened. He was right, after he put the cap back, the leakage disappeared during idle. This morning, after the drive to work, I notice the leakage again. A lot less this time, but still there.
I will take the car to the MINI dealer, get a new filter cap (I also broke a little piece that pushes the filter to the housing) and have them put the cap back and torque it exactly to 25nm...
Anyone had similar issues?
Old 09-07-2011 | 09:35 AM
strobeyprobey's Avatar
strobeyprobey
Luckily that cap is under $30. As long as you didn't crack the filter housing (some BMW models experience this as a common) you should be fine. And if you did crack the filter housing, that part is $124 on parts dot com.
That specified torque sounds too high to me. But I haven't changed my Cooper's oil filter yet (still running on the last dealer oil change)
Old 09-07-2011 | 09:37 AM
Erhan's Avatar
Erhan
We checked both the cap and housing, nothing seems to be cracked. In anyways, how a plastic cap can crack a metal/aluminum housing?
My friends theory is that if you over tighten the cap, the oring is pushed hence not sealing the cap.
Old 09-07-2011 | 09:40 AM
strobeyprobey
The filter cap o-ring was included in the filter kit right? Try your old seal if you have it still. Or get another filter kit and try a new o-ring.
Old 09-07-2011 | 09:42 AM
Erhan's Avatar
Erhan
Yes the filter cap o-ring was included in the filter kit (which is OEM MINI filter kit). I can't try the old seal, I am at work, but thanks for the suggestion.
Old 09-07-2011 | 10:07 AM
Herleman's Avatar
Herleman
I dropped my filter housing on the first oil change, must have hit the concrete just right because it broke it.
A new housing cost me about $80 at the dealership. The parts guy said the stock them because they get broken rather often.
I suspect yours just got the "o" ring out of place on the first try. Easy to do.
Remember to put some oil on it after you install a new one so it can slide smoothly to its seated position. If you don't oil it it can catch and deform as it drags on the oil pump housing.
Get a new cap, a new ring, put some oil on it and torque it back in place, it'll be fine I'm sure.
Old 09-07-2011 | 10:45 AM
Jolio's Avatar
Jolio
Does the filter itself have to be place the same way the old one was. Placing the new one upside down, can that impose a problem? Just wondering.
Old 09-07-2011 | 10:49 AM
Erhan's Avatar
Erhan
Maybe..? The filter looks identical both ways.
Old 09-07-2011 | 12:38 PM
Erhan's Avatar
Erhan
Mystery is resolved. Apparently, the o-ring is not supposed to be all the way up to the 'head' of the cap. The shop foreman fixed it. He said, the o-ring needs to be where all the treads are finished. He said there's a groove there, and the o-ring should be there.
Kimolaoha
07-05-2023 02:04 PM
woodstudio
03-15-2020 09:28 AM
Colt45Magnus
07-14-2019 07:18 PM
patpatpat
08-27-2015 08:51 AM
HaveATank
08-24-2015 11:26 AM
