Intake Boot Clamps
Intake Boot Clamps
'03 MCS: I recently did some work under the hood (ahem, bonnet) and in the process had to disconnect the rubber intake boot from the throttle body. How the hell do I get the hose clamp to re-tightened? I tried unsuccessfully with needle nose pliers. Is there a special tool or technique? Or, should I just buy old fashioned clamps that are tightened with a screw driver?
It's been a while since I had the stock intake hose on but if it's the same type as the one pre-filter at the front grill, I use a plier to close them while sticking a thin flathead screwdriver blade through the bit that locks. Once you squeeze the clamp with the pliers past the notch, remove the screwdriver and it's locked. You might have to rotate the screwdriver to help get it over the notch. This works great on the upper clamp but it might be hard to get to the one by the throttle body.
The technique I learned from Randy Webb - use a set of channel locks (ideally a small pair, referred to as 'ignition pliers'), Put the top jaw on the 'over' portion of the clamp, and the bottom jaw on the 'under' hump and squeeze as you roll them back, pulling the top over the hump. It takes a bit of practice, but once you get it the method works well.
But, now I'm motoring again.
67morris
12-01-2015 12:53 PM
COOPT UP
09-11-2015 04:59 AM
kjd186
09-09-2015 10:02 AM
