Timing Chain Tensioner Measurements
To measure the chain, you use a tool like this:
http://www.ntxtools.com/Merchant/mer...&Store_Code=01
Put that in where the tensioner goes, tighten it down to some very small torque number (basically as soon as the chain is tight), take the tool out and measure. If the measurement is more than like 68 mm, you should replace the chain.
* note - workin off memory - verify numbers with appropriate sources. Just trying to explain the concept.
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
iamcamkeenan
08-10-2015 03:31 PM
