Belt Damper Bushing coming out
I had the OEM damper bushings replaced with powerflex ones a few months ago, the lower one had disappeared completely so I just decided to swap them out. Strangely though, the powerflex one is beginning to come out ![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
Any ideas as to what may cause this? The belt damper was replaced a few days before the bushing disappeared(at a dealership), it's not more than a few months old (3-4 months at most) so i'm pretty sure it's not that. For some reason I feel as though the bolt head on the bottom of the piston is smaller than the top, causing it to slip out..dunno, just an idea..
Just went outside to check it out, the bolt still seems to be in there, I stuck my hand in to check and everything. The bushing seems to be going around the bolt. I tried to get a better picture of the front of the bushing, but it's a tight fit.
on
Again, totally plausible. I'm going to try and head over to the dealership a little later. Since they swapped it out a few months ago maybe they can put a washer on there, or at least pop the bushing in properly.
If you need to replace them, then yeah they definitely are, they have a lifetime warranty, so i'm getting a new set for free. If you don't need to replace you're bushings then you're fine. Check your control arm bushings and such, powerflex has replacements for those as well, and a few others. Go to waymotorworks.com and you'll find them
silence2-38554
11-12-2015 09:39 AM
minipopkart
08-13-2015 05:22 AM
iamcamkeenan
08-10-2015 03:31 PM
PelicanParts.com
08-04-2015 02:45 PM
