It seems to always be something new :(
Well once again my 02 MCS is down. I got a P0108 code along with a P0303 code and it said misfire in cyl 3 so I pulled that NGK plug out and the insulation was cracked on the firing side under the 4 prongs so I replaced all 4 plugs with new NGK iridum? plugs and I also replaced the pressure switch in front of the supercharger and now the car misses badly at idle and is in limp mode pretty much as soon as I start the car. I put the old plugs back in with a new one replacing the cracked one and it's no better. I have a brand new MSD ignition and brand new MSD 8.5 wires. It still shows the same codes after clearing the engine light. It seems like this car hates me. It's been the worst car I have ever owned in my life for dependability and I've drove them all. I'm starting to think Corvair made it. I definitely have a love/hate relationship with it. What's next???
on
Ouch, well a buddy of mine had that happen to him on a honda. the injector actually started to die which leaned out the cylinder really bad and it burned a hole through the crown of the piston. Post back with what you find, and if you do have to end up really tearing into it, be sure to have the injectors tested.
