Help me find Diverter Valve
Hey guys,
I've done quite a bit of searching, but with such a broad term as "Diverter Valve" its quite difficult to find what im looking for.
I have a used 07 Mini Cooper S, Auto, that the previous owner put a universal Perrin blow off valve on it. I think its the cause of some of my drivibility problems and i'd like to see about returning this to stock.
A - can I see a pic of the stock intake/bov (or diverter) setup so I can see what I need to do to get back to stock.
B - Does anybody have a quick write up on location and how to remove/ check the diaphragm of the diverter valve? I'm losing boost under hard accel and I think i might have a rip. I have no idea where to find the DV on this little motor, LOL.
Thanks guys. BTW I put in an email to find out about the Helix BOV setup, seems like it might be a good option if i'm about to start changing things under the hood. Opinions?
Thanks again
Thrux
Thanks again
Thrux
(* NOTE: the polished bolted on unit with the vacuum line hose is an example of a Forge Motorsport diverter valve installed)
Scan the ECU with a Bavarian Tech scanner to see exactly what's going on.
Otherwise removal of the DV is simple, and visual inspection is easy to determine failure or not.
- Erik
07-16-2020 12:54 PM
