Rear Wheel Bearings
Rear Wheel Bearings
We tow our 05 MCSa behind a motorhome, front wheels on a tow dolly.
Which puts more pressure AND miles on the rear bearings.
Are the rear wheel bearings sealed or can they be serviced?
I would MUCH rather do a little preventative maintenance than call a tow truck in the middle of Wyoming or Arizona, etc.
ab
ab
Haynes shows no service procedure, and say they are non-adjustable; "wheel bearings are integral with the hub and not available separately. Now someone is going to tell you next how you can rebuild a hub but recommended procedure is if worn you replace the hub. Once the brake assembly is out of the way, you remove the wheel speed sensor and 4 bolts hold the hub in place. Very straight forward.
I was afraid they were non-serviceable.
I did a search and didn’t find much about the rear bearings, seems to SOME early failures with the front.
I have an infrared thermometer. I’ll just keep checking ALL (8) tires and bearings every time we stop.
Again
ab
07-16-2020 12:54 PM
ClayTaylorNC
08-10-2015 09:19 PM
