Fog Lamp Light out, replace it myself or dealership?
Old 02-19-2004 | 01:04 AM
NRX13's Avatar
NRX13
soooo after my wheel well light almost caught fire... and the car was in the shop for a week... thats fine and dandy now.. however, my front driver side fog lamp either..
A. Burned out
B. caught fire as well (i hope not)
Im thinking the bulb just went out...
soooo my question is, how does one change these lil buggers? I havent had a good chance to look unerneath the car to see if its easily accessable, do you think i should bring it to the dealership to have replaced or do it myself?
thanks!
Old 02-19-2004 | 04:06 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Out of all the exterior lights, the front fog lights are the least accessable. It might be easier for the dealer to do it if the car is still under warranty! :smile:
Old 02-19-2004 | 05:52 AM
dandp's Avatar
dandp
I had it done under warranty. But ask first...some dealers may hem & haw about it.
Old 02-19-2004 | 05:54 AM
koolmini's Avatar
koolmini
dealer installed fog light blub should be covered by the dealer warranty
Old 02-19-2004 | 10:46 AM
dave's Avatar
dave
pug poo picker-upper
If anything goes wrong with the foglights (other than bulb replacement), MINI only calls them out as the entire assembly, so you (or the dealer) will have to order the fog light assembly (specific R & L). MINI does not have a part number for the foglight bulbs, but the dealer may stock the H11 bulbs anyway (not sure on that one).
I replaced both my foglights after the lenses cracked.
- You have to remove undo some connections in the wheel well liners to access the fog light mounting screws
- I found it helped to also remove the bumper cover to see a little better what you were aiming for (the screw)
- There are also some connectors that need to be undone.
The major pain is getting those three screws that hold each foglight undone and then getting the screw started again when you install the new assembly.
The new foglights will also need to be reaimed (not the case with bulb replacement).
Given all that, I would try to get the dealer to warrenty your foglights first, and only do the replacement on your own if you have to. Incidently, if you have to order the fog lights and replace them yourself, call the Classic MINI parts department.
Dave
Old 02-19-2004 | 10:45 PM
coopstas's Avatar
coopstas
It is very easy to replace those lights. Pull the front wheel and there are 4 screws to remove.If you need help you can email me. robgamber@comcast.net
Old 02-21-2004 | 09:44 PM
911Fan's Avatar
911Fan
You've already paid for the warranty. Why not let the dealer take care of it for you?
Plus, it might be something more serious than just a bad bulb, like a cracked connector or a bad wiring harness. If you mess with it yourself, the dealer will have an excuse not to cover it under warranty.
Old 02-22-2004 | 08:05 PM
fishey72's Avatar
fishey72
This would make an excellent how-to page like Randy has in performance mods, could be very usefull to many?!? Pictures worth millions of words n'stuff. :smile: Especially when I have to replace one of those and I am a long long long way from the dealer.
Old 02-22-2004 | 08:22 PM
DVLMINI's Avatar
DVLMINI
If you've already had an electrical fire, I'd make the dealer do it.
Old 02-23-2004 | 12:22 AM
NRX13's Avatar
NRX13
Give me less than 20,000 more miles and i'll do a whole bunch of howtos once my car starts falling apart (again)
For now i'll leave it up to the dealer to correct these problems.
07-16-2020 01:54 PM
12-23-2015 11:36 AM
JamJam43087
08-16-2015 03:02 PM
DWooderson
08-10-2015 10:12 AM
08-07-2015 09:02 AM
