Strut Mount Squeak
Strut Mount Squeak
I have been dealing with a squeak in the steering wheel ALL YEAR LONG and last night i finally found out what this noise was coming from. When i popped the hood and had a friend turn the wheel, sure enough i could the noise much louder and felt the mounts vibrating. I looked around and saw cases where putting grease into the mount underneath the llittle cap thingy (I didnt even know it came off) and noise went away. Does this work? Well guess im about to find out....
Had you replaced the front struts over the past year when the noise had started? I had a problem when I swapped out my struts, my coil overs were "creaking". I had to crank down the top nut not he strut until it felt like it would bust off. The strut had an allen fitting, put a socket on the top nut and cinched down as hard as I could. It creaked again when I turned the wheel, so I did it again even harder, and then it had completely stopped. It felt like I was going to snap the allen wrench.
Supertractor3
04-07-2017 11:16 AM
09-04-2015 02:34 PM
M7Speed
09-04-2015 10:47 AM
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
