Blue liquid leaking onto driveway under engine compartment
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Actually I stand corrected; I think it is coolant from the way it was running off the paper I laid down. It wasn't viscous. I was just surprised because I always thought coolant was green.
Bmw mini coolant is blue...
you are likely overdue to get it changed...it is not longlife, and not the same as yellow/green...similar, but not the same.
Late update... but I ended up changing the Thermostat Gasket and Housing. It took me about an hour or so to do the replacement and then another half hour to re-fill coolant and bleed system.
